Photo/video tripod. Manfrotto 116 (Bogen 3066) Head & Bogen 3061 Tripod Legs. This tripod leg/head combination is designed for studio use for cameras up to 35 pounds. The system is in excellent condition with little use; all screws, attachments, parts, in great working order. Shipping/storage case available, extra. Note: this tripod was originally designed as a PHOTO tripod, could be used for large camera/lens -where both photography and video are shot, or for heaver video rig. I used this in my studio for the occasional video shoot, so it's been lightly used and well cared for. Stored in it's shipping container when not in use.
The ideal studio location tripod that can support cameras up to 66lbs! The leg spread is fully adjustable with Aluminum outer and chrome steel inner leg extension. The head support incorporates a 90mm Bowl for ball mount heads and rated for supporting up to 66 lbs. The leg spread is fully adjustable, The built-in claw ball levels your camera quickly, even under the most uneven conditions. Built-in chain brace ties are standard (chain is missing).
This Manfrotto 116 video head is the same as the US (Bogen) 3066
The 116 fluid tripod head, heavy duty type for large film / tv cameras up to 35 pounds.. With a ball mount head that can be removed for a flat profile mount with one bolt. Cast aluminum design. Includes tripod plate and two arms. The 116 head is designed for use with cameras weighing up to 35 lbs, incorporating variable balance adjustment and a fixed drag system which allows for finger tip control at all times.
116 Specifications
secondary safety lock
leveling bubble
Pan: 360
Tilt: +70 -70
Independent Pan Lock
Independent Tilt Lock
Maximum Load Capacity: 35.3 lbs.
Head Height: 5.2 inches.
Pan Drag: 1 Fixed
Pan Handle: 2
Tilt Drag: 1 Fixed
catfish@cahoyt.com
116 Specifications
leveling bubble
Pan: 360
Tilt: +70 -70
Pan Drag: 1 Fixed
Pan Handle: 2
Tilt Drag: 1 Fixed
catfish@cahoyt.com
