How are those Feisol legs, anyway? I have Millers but was looking for something smaller.
I originally owned the Sachtler ACE M tripod, and eventually replaced it with the FSB-4 because I found that the ACE M head had a little bit of kick-back at the end of a pan, where the FSB-4 did not. You also might consider other legs with the Sachtler FSB heads, like the Manfrotto carbon models or the Miller SOLO legs. ( Miller are very quick to set-up and can be used on un-even platforms like stairs )
Thank you very much for your response and helpful info! I was under the impression that all tripod legs with a mid-level spreader could be used on uneven surfaces like stairs.
There hasn't been a post in this thread for a while but I am looking of an a7s or (a7r ii) tripod. I have done a fair amount of research. A suggestion that I have seen a few times is combining a Sachtler FSB head with Miller Solo CF legs. Do you guys think this is a good way to go? In terms of future proofing it seems like the fsb-6 or 8 would be the way to go but my budget could only really go for the fsb-4.
As for the legs, I always see mentioned "Miller Solo" legs but they come in a 2-stage (http://www.bhphotovideo.com/c/product/293495-REG/Miller_1501_SOLO_DV_Carbon_Fiber.html) or 3-stage (http://www.bhphotovideo.com/c/product/327753-REG/Miller_1505_SOLO_VJ_Carbon_Fiber.html). Would anybody recommend one over the over?
I know it would be easiest if I just went and tried some of the options out but I don't have any shops locally that stock these so I will be buying online.
Thanks!
It's really a function of whether you need the shorter folded length or not. 2-stage will be slightly faster to set up, and ever so slightly sturdier. But short is handy.
