I have yet to buy a DVX200 but am leaning strongly toward doing so. In preparation / anticipation of same, I am seeking a tripod for in-car use for filming severe weather. Given lightning, rain and the need to quickly change locations, I nearly always shoot exclusively inside the car, and already have Manfrotto tripod legs suited to that greatly constrained / contorted location.
But I need a tripod head that is not too big esp. not too high; strong enough for a camera the size and weight of the DVX200; and - here's the trick: 3-way pivoting, because the road is often not level, particularly the side of the road where one can safely pull off so as not to obstruct traffic (makes sense and mandated by authorities for good reason). I will get metal cutting tools to remove most of the center pole, as it interferes with the 6-speed shifter.
So my tripod head needs are:
1) 3-way controls not just ball head; and I don't have a half-ball tripod.
Most 3-way tripod heads are for photography not video use, and have friction heads.
Most video heads are 2-way: fwd/back tilt and pan Only. Grrr.
2) fluid control (or just for panning; this is preferred but not critical)
3) not too tall. the dvx200 camera lens has to shoot between the rear view
mirror above, and the LCD display below (2016 mazda 3 hatch).
3) longer mounting plate suited to dvx200. Most photo head mounting plates have a shall we say 4x3 (!) shape.
most video tripod mounting plates are longer, but sit within 2-way tripod heads.
Those with DVX200s: please tell me -
a) how tall is the DVX200 from mount at bottom to very top with lcd display extended left?
I thought I saw 8", is that right?
b) what is the size, length x width, of the mounting base at the bottom?
I'm afraid standard tripod head mounting plates are not long enough.
It might work but be "wobbly". And there have been comments about off-axis (L-R looking down lens)
weight of the camera (Adam Wilt's review on dvinfo.net). I haven't seen mounting plate adapters but worry
that the usual tripod head top / mounting plate size won't do, for the dvx200.
c) how much of the dvx200 extends forward (looking down-lens, in inches) of the mounting plate location, and how much extends aft?
I imagine some will say: GoPro (cost/4K is great but quality/flexibility are not). Others may say: window mount - no, given road application, shake/bumps, concerns about in-car objects in case of an accident. Everything must be locked down.
I imagine some will say: for heaven's sakes, use a DSLR. Indeed the Sony a7s ii has been of interest for its outstanding low-light prowess, but it could shoot for perhaps 30 min before shutting off. That won't do, and I have many interests beyond weather and DSLRs are not suited to most of them, and I don't have the glass (yet), making going with a DSLR or Ursa Mini 4.6k potentially much more expensive. I'm keeping my eye on the future GH5 (?), or perhaps an additional GH4 for matching multi-camera work in the future. I want a single camera to buy, and renting complementary cameras / lenses makes more sense right now. At present I have an old dvx100(a!), and an inexpensive HD camcorder.
I need: good dynamic range (skies do that...), 4K for one particular application in mind, run (drive!) and gun use, flexibility (which seems to be the dvx200's forte) and prefer 10-bit 4:2:2 (thus external recorder if I go with the dvx200). Like many, I wish there was 4:2:2 10-bit in camera recording and constant aperture if zooming, and a faster lens. Actually, my main DVX200 wish is for a 2nd telephoto lens option, for perhaps $2k more, that was faster/wider, with similar electronic correction for distortions as is done now. I wish...
From reviews so far, for tripod heads that aren't too expensive, I'm looking at these:
Manfrotto MHXPRO-3W X-Pro 3-Way Head
Manfrotto 804RC2 Basic Pan Tilt Head
Davis & Sanford FZ10
Davis & Sanford FGX10 3 Way Pan and Tilt Head
Davis & Sanford FX13 3-Way Fluid Head
Regrets at the long post.
Any comments on dvx200 dimensions, and on tripod heads would be much appreciated !
I hope to be a DVX200 owner soon, but have to make sure it is feasible for this application first! And for that: a suitable tripod head.
Brian
Brian
