Travel tripod for my A1
Sirocco
I travel a lot: USA, Europe and Asia; the tripod as to be as light and small as possible ; any advice for a my configuration:
Canon A1 (4.5 pounds)
filter, batterie and tape
WD-H72 ( don't know the weight)
G2 receiver, Videomic
vidled deluxe (1 pound)
some kind of bracket to hold the light
It must be around 7 pounds, depending on the weight of the WA.
I was thinking of the following: 701 RC2 with Manfrotto Mag fiber tripod 190MF3,
I would mostly use the tripod for interviews. Any advices from you experience people?
My travel tripod has been the 700rc with same legs (not mag fiber, but size) and I think it is not a great set-up. Maybe things have changed with new models, but it ain't great for pans and tilts. If you truly are just doing interviews, then it will be fine. Then again a stack of bricks will do fine (very strong, although heavy).
I am in the hunt for a new set-up and if I had to go on the cheap, I would do a Miller solo dv CF legs with the new Bogen 501 HDV. It should be close to your weight requirements and probably more money. I can't speak from experience with this gear, so someone else can chime in (especially the head). I am leaning towards the Miller VJ legs and Cartoni Focus head.
Sorry I don't. One thing you can do, is find it and rent it. Tripods are usually cheap to rent and you can try it out for yourself.
I just purchased a Bogen 755MF3 with a 503 fluid head. The combo is about 8 lbs total and feels great (I don't have the shooting time in to really qualify it either way beyond that). I went with the carbon fiber legs specifically to keep the weight down for everyday use... might be fine for travelling too.
I use the manfroto 503 fluid head and Gitzo 2530 carbon legs.
The head is very smooth and you couldn't ask for lighter legs
My A1 balances very well on this combo
I carry the libec th650dv all around Europe and to Asia sometimes. It is really solid and light. gives me a fast levelling time because of the 65mm ball. It works fine for me when you need to travel alot and keep gears light and still have a good tripod to work with.The tripod takes up to 4kg and weights 3kgs (7pounds). go here for more spec: http://www.libeceurope.com/acatalog/Basic_Products.html
I ended up choosing the Manfrotto 055MF3 with the 701rc2. I will keekp an eye on the new 503hdv wich should also fit well with the legs, but I really wanted something conveniant for travel and interviews. I'll let you know about it, thanks for all the advices.
