Travel tripod + fluid head
rawfa
Hi guys,
I´m looking for a small, light tripod + head for my photo and video work. I´ve been reading a lot of specs and reviews and I´ve come down to these:
Tripods
Velbon Ultra REXi L Aluminum Tripod - us$185
Load Capacity 8.81 lbs (4 kg)
Maximum Height 5.01' (1.53 m)
Minimum Height 3.74" (9.5 cm)
Folded Length 14.17" (36 cm)
Weight 2.88 lbs (1.31 kg)
Benro MeFoto A1350Q1A - us$230
Load Capacity 17.6 lb (8 kg)
Maximum Height 5.13' (1.56 m)
Maximum Height w/o Column Extended Not specified by manufacturer
Minimum Height Not specified by manufacturer
Folded Length 15.4" (39.11 cm)
Weight 3.6 lb (1.63 kg)
Fluid Heads
Manfrotto 128RC QR Micro Fluid Head - us$85
Load Capacity 8.8 lbs (4kg)
Diameter/Thread 3/8" female thread
Counter Balance System Not applicable
Counter Balance Range No
Center of Gravity Not specified by manufacturer
Quick Release/Wedge Plate Yes, (200PL-14)
Balance Plate Fixed, 1x 1/4"-20 screw
Tilt Drag Not applicable
Tilt Range -60/+90°
Tilt Lock Yes
Spring Loaded Counter Balance Not applicable
Pan Range 360°
Pan Lock Yes
Leveling Bubble/Illuminated No
Temperature Range Not specified by manufacturer
Weight 2.2 lbs (1kg)
Manfrotto 701HDV Pro Fluid Video Mini Head - us$125
Load Capacity 8.82 lbs
(4kg)
Diameter/Thread 3/8" Female Thread
Counter Balance System Fixed counter-balance spring @ 1.5kg
Counter Balance Range 58mm
Quick Release/Wedge Plate Yes 501PL
Balance Plate Fixed, 1/4" Screw and Locating Pin
Tilt Drag Fluid Cartridge with Fixed Drag
Tilt Range -60/+90°
Tilt Lock Yes
Spring Loaded Counter Balance 1 Fixed
Pan Range 360°
Pan Lock Yes
Leveling Bubble/Illuminated Yes / No
Temperature Range -10°C / 60°C
Height 3.7" / 9.5cm
Weight 1.8 lbs (0.83kg)
For day to day photography (90% of my time) I think any of these would work, as I use the NEX7 and my heaviest lens is the Tamron 18-200mm e-mount.
For video things get a little heavier as I might mount an H4N recorder (9.9 oz / 280g without batts) and a shotgun mic (5.74oz / 163g).
Taking a look at how much these fluid heads weight I think I´ll be almost "forced" to go with the Benro as his Load Capacity is 17.6 lb (8 kg)
Any thoughts, experiences and so on with the equipment above?
Velbon make some cheap and very light tripods with grease-filled "fluid" heads, which are amazingly good compared to price. If possible try out a C-600... I have one of these for my C cam. It is not sturdy enough for a glidetrack and the like, but will give you very fluid movement for very little money. For vertical format photography you can mount a small ballhead on the head...
I´ve just got a good deal a Benro MeFoto A1350Q1A and I will probably get the 701HDV. Like I said, I do photography 90% of the time and when I shoot video I don´t use a very heavy gear. I read that a bunch of people hang some weight on the tripods´ hook so it´s more stable. Anyway, I´ll post my first impressions once I receive the tripod.
Bought a Manfrotto 190XDB 3 section tripod that supports up to 11 lbs. and weighs 3.5 lbs. and use it with a Vanguard ball head that has a separate pan control knob. If the tripod head is level I can pan easily and do minor tilt adjustments by setting the tension on the ball. The Vanguard SBH-100 supports up to 22 lbs. and it weighs 16 oz. so with the tripod the total weight is 4.5 lbs. for a very sturdy tripod with a very good ball head.
