I just purchased the steadicam vest and arm upgrade for my merlin, but just curious how people transport everything around. I know there's the Steadicam backpack ($330), but does that fit the entire package?
Pull the pin at the "elbow" of the arm to split it in 2.
Wrap them in some sort of padding - a spare t-shirt works just fine, or you can get a cheep piece of fleece from any fabric store and use that to wrap up the arms (just so they don't bang into each other).
Then put that whole lot inside the vest, and then all together into a bag or case. Slightly padded cases are preferred, but the vest is already so padded that any duffel-bag or suitably sized backpack will work fine.
the case that came with the steadicam pilot is all about padding and protection. for most transportation it wouldnt be necesary but i can say that if ever dropped there would be no worries. its almost all padding inside. it is rather bulky though. might be a little overkill for the merlin.
in this case the two pieces of the arm gets split with one on each side of the case. the vest lays on top of all of the other contents with a piece of foam between it and the rest of the pieces. there is a sizable front zipper compartment in front of it for batteries/accesories.
its a nice robust case. it did come with my steadicam pilot. way too big to take on a plane though.
I have a big rigid soft case that my Steadicam originally came with, but if I didn't have this I would take the dimensions down on paper that are required to store everything, and then find a hard case for storage.
I have hard cases for almost every piece of equipment I own, and not only does it protect your equipment, but it makes one look very professional....much more pro then gym bags and cloth wrapped equipment.
Yeah, let me clarify; the arm in the vest in a bag is great for compact transportation if you are reasonably nice to the bag. (= don't check it with an airline!) I use that method when traveling light to shoots semi-locally.
But most of the time my Steadicam lives in 2 full size Steadicam hard cases. (The arm within the vest in one of them.)
I simply love those cases miko! My rigid soft case pales in comparison
I'm actually upgrading my storage right now to full on hard cases. The Steadicam is a beast and can hold up in the semi-rigid, but nothing keeps your mind at ease like an array of hard cases and a good cart to move everything around on....now I just need a pack mule, lol:thumbsup:
