[FS: General] Tote Vision LCD-703HD 7" LCD Field Monitor Canon LP-E6 Battery Powered
mrousseau6588
Selling a Tote Vision LCD-703HD 7" LCD Field Monitor conveniently modified with a Marshall power adapter that uses Canon LP-E6 batteries (same batteries for the Canon EOS 7D and EOS 5D Mark III). It can also be powered by the adapter or by an included AC plug.
Here is what is included:
Marshall Power Adapter for Canon LP-E6 Batteries
Quantaray Large Case
VariZoom VZ-AR-5K Adjustable Joint Arm (with Clamp)
HDMI to DVI adapter
Remote
AV Adapter/Plug
The monitor alone is over $600 new.
This is a great low cost alternative to other field monitors.
It is perfectly fine for checking critical focus. There are only two caveats:
1) It does not have an HDMI input. I'm including an HDMI - DVI adapter, which will allow it to be used with a DSLR camera.
2) The monitor auto corrects the aspect ratio when using DVI, so image may appear stretched. You won't have this problem if you use component video.
Asking $400 O.B.O plus shipping.
If interested, email: max@politefilms.com
