The reason is that each P2 card is seen as a separate disk. So each card you dump on the P2-store must be seen as a separate disk also. For this, the hard drive is partitioned into 15 separate partitions, so your OS ( XP or OSX) thinks it sees 15 separate disks.Cam-Ra said:The camera is limited (for some unknown reason) to copying only 15 times to the same hard drive before a re-format.
eLeventy said:The reason is that each P2 card is seen as a separate disk. So each card you dump on the P2-store must be seen as a separate disk also. For this, the hard drive is partitioned into 15 separate partitions, so your OS ( XP or OSX) thinks it sees 15 separate disks.
Partitioning is limited to 15 partitions per drive in the Master Boot Record.
