to light talking head in small space-softbox vs fresnal
here is the situation:
camera-canon 5d or 7d
lens-nikon ais prime 50mm 1.8
i have to shoot a series of upbeat talking head-12 of them-during the course of a 2hr corporate event.
the only available space is a corner office away from the gathering.
the office measures 14' x 10' but i can not totally remove the contents of the office.
consequentially, i have one spot for the interviewees to stand.
that spot is approx 4ft from the black fabric background i will put on a stands
the camera will be 8ft in front of them.
the ceiling is 8ft dropped ceiling.
i have access to two lighting instruments for my key-a small (rather than large or med) softbox with a 500watt daylight bulb (also have access to 3200 & 5600 bulbs) or a 650watt arri fresnel.
all the interviewees will be standing & are youngish, vibrant and energized-20yr-40yr-of varying heights and some-unknown amount-wear glasses.
i have 2hrs to interview 12 folks.
that means i have approx 10min with each-including lighting tweaks.
if i use the softbox as key, 45degress from camera/45 degress up, the light should be fine
but i'm worried about the spill from the softbox and glasses reflecting the lights.
i would then use a reflector as fill creating a flat look w/o much contrast but their youngish qualities will look more vibrant.
if i use a 650 fresnel as key, a can barn door/snoot the light allowing me to control the spill. i would then use a 250 bounced for fill.
both would have a 150 watt has hair/backgrd light.
i am concerned that the lighting tweaks between interviewees will chew up my time and leave me less time for the q&a.
so, softbox or fresnel?
or perhaps another thought?
thanks in advance.
be well
rob
smalltalk productions
thanks in advance.
be well
rob
