filmguy123
I have 128gb of SD card space on my AF100 and often times will shoot multiple projects/videos onto the SD cards. When doing this, I will copy the SD card content to my computer, and then continue shooting (without clearing cards - so that I can keep multiple copies of clips for as long as possible, AKA home HDD, backup HDD, and SD card).
Problem is, when I come back to copy the clips to my computer after a NEW shoot and still have previously-copied clips on the SD card from an OLD shoot, it's a pain. Because now I can't just copy the whole SD card without duplicating previously copied clips. And my understanding is, I can't just drill down into the private-BDMV-Stream folder and pull out the MTS files if I want to keep metadata, etc. in tact.
Wish I had a good/easy/fast system to pull of only the NEW clips added to AF100's SD cards (new since I lasted copied card contents) to copy to HDD, while keeping all file structure/metadata in tact.
Any workflow tips?
Or is the only way around this to clear memory cards completely between each shoot, or buy more SD cards?
And/or, how neccessary is it really to keep full Card Structure in tact?
Or is there a software the copies entire card contents/file structure of NEW files since a certain date (i.e. date of last import). An app like that would be cool.
Any workflow tips?
