S snpx Active member Feb 17, 2008 #1 in timelapse mode 720p50 i get 2 frames and not only one, wich would be normal. could you please test it with your hvx, because i dont know, if its a fault with mine. thanks in advance.
Filmbuff28 Well-known member Feb 18, 2008 #2 Are you using time-lapse (Interval) mode? The frame rate hack? Or general variable frame rates?
S snpx Active member Feb 18, 2008 #3 yes, i`m using the interval mode wich should result in one frame every x frames, isnt it?
S snpx Active member Feb 18, 2008 #4 nobody? sorry, did not tell its a hvx200e (pal), if this is imprtant. Last edited: Feb 18, 2008
