Timecode display on external monitor
SLordUK
I think I already know the answer to this but... the composite output only shows a few useless bits of info, but doesn't show the Timecode (the most useful to PAs). Am I missing a menu somewhere?
I dont see a way to display LTC on the composite out, I just checked the menus. But if you have a SDI monitor that can display TC then you can see it there, SDI includes TC.
The NanoFlash also displays TC if you set it to TC from SDI signal. That can be useful if someone is logging TC.
I often set TC to TOD and then have a slate with a digital clock jammed to the same TOD. The PA can then see the TC on the slate. You can also use an Iphone or similar device to display jammed TC.
It would be a nice firmware change (in addition to focus assist) to have some HDMI and/or SDI display info from
the camera ( TC, safes and such).
jeff
