Time code
Alcham
Hello,
I've got a problem with my time code on the DVX-100 :
After log and capture my footage (in FCP 5), when I take back the cam to shoot, the time code is reset to zero and I do not understand why.
Any idea ?
Thank you.
Sounds like your camera is set to Regen in the First Rec TC menu. That means that when you pop the tape out and replace it with another (or the same one), the TC counter will reset itself if there's no timecode on the tape. If there is timecode on the tape, the cam will try to pick up where it is on the tape.
Hi & thank to you.
So what to do to avoid this zero reseting ?.. I just want to keep the same time code on my tape after having capture a part of my footage. Changing the First Rec TC to preset is the thing to do I guess..
I'll try & see.
Thk
