For time code we want Free Run and have set that on the HVX-200 and will synchronize the cameras via 1394. What should the FS-100s be set at?
How should the Pre-Cache recording be set up? On the HVX-200 or on the FS-100.
We had the Pre-Cache set on the FS-100 and had problems getting the HVX-200 to record when we pressed the record button. Switched off the Pre-cache on fs-100 and set it to normal and then everything was fine. We have 2 FS-100s and 2 HVX-200s and on one FS-100 (the one with no problem) it said E Rec and the one with the recording problem (wouldn't start recording) the fs=100 said C Rec. We turned of the pre cache on the fs-100 and then it went to E Rec.
