David Evans
Anyone tried this wireless follow focus? I've been reading good things about it. Does it deliver? I'm ok with some workarounds. For the price range, it looks pretty sweet.
So power it off a 12v P-Tap.
- The opposite is true for the controller. I don't use the included battery because there's no indicator as to drain and when it might fail. instead I power it off of USB but in this case it can ONLY accept 5v power. So if you want to power from P-Tap then you need a cable with a regulator in it. This is the opposite of the cable you want for the motor.
- IndyPro Tools makes (at my request) these cables. 24" cables that are both P-Tap to MicroUSB, one with a 5v regulator and one without.
Mitch, are these the links for the cables?
https://indiproco.com/?term=&s=Nano&post_type=product&taxonomy=product_cat
Jim Arthurs
I get a chuckle out of self-declared experts on YouTube who clamp the focus controller to the side of their camera, they're clearly missing the point of a wireless follow focus. You can get a decent manual follow focus pretty cheap these days, so I think it makes sense to use a manual FF for general shooting and use wireless when it's warranted, like for crane, steadicam, or gimbal shots.
Thank you all for your input, guys. I'll mainly use Zeiss Contax lenses with this FF, but even though most of them have very smooth focus, the 28mm F2 is a beast. Will powering the FF with 12v be enough? I think I saw a video somewhere of a guy who could pull focus on the 28mm Zeiss Contax with the regular motor powered by the 12v, instead of 5.
