This arrived today. I hoped I could use our Hawk Woods 12v distributor plate on there, but the two won't mate at all easily. It turns out the Tilta power plate one isn't too bad - only one D Tap socket, but I'm only running an additonal Micron radio mic receiver on there, so will see if that will run without issue from one of the other regular power ports.
One advantage - the V Lock batts slip on and off the Tilta plate far more easily. After a year, the HW plate is still too stiff and you can end up destabilising things trying to get it on and off.
One tip - it needs a couple of spacer washers under there, which weren't supplied. Otherwise, it fouls against the FS7 bodywork slightly. I've attached a pic to show the resulting clearance. All feels pretty solid. Bought it here in the UK from Cinegear Pro.
Ben.
Ben.
