Erik Naso
Tilta 15mm Quick-Release Baseplate for Sony VCT-U14 Tripod Adapter. I did use the stock Tilta camera plate and as of now cant find. instead I used the Manfrotto 357 so I'm including both camera plate and quick release clamp. Retails $63. This way you can add the clamp to a tripod.
$285 plus shipping or free shipping if you use gift option with Paypal.
Perfect working condition. Some scuffs and scraps from having it with other grip gear in the bag. I know I shouldn't do that
Click Here for grips on DVXuser
Description:
Easily mount your camera onto a tripod via the Sony VCT-U14 Tripod Adapter using the Tilta 15mm Quick-Release Baseplate from ikan. The V-lock system on the underside of the baseplate locks firmly onto the Sony VCT-U14, which can then be mounted onto a tripod’s wedge plate. Alternatively, the baseplate’s quick-release mechanism allows you to easily detach it from the VCT-U14 and switch to a shoulder mount/handheld configuration.
You can make front and back adjustments thanks to the adjustable shoulder pad which is padded to give you comfort while carrying your camera on long shoots. In addition, since the shoulder pad is located at the center of the underside of the baseplate, it allows for optimum balancing for the safety of your camera system.
The height-adjustable 15mm rods adapter allows you to adjust the height of the 15mm rods for appropriate placement of accessories.
V-Lock system provides rock-solid connection to tripod with Sony V-Mount VCT-U14 Tripod AdapterEasily and quickly change between studio and handheld configurationsAdjustable shoulder pad allows front and back adjustmentsPadding material provides more comfort and better fit on your shoulderCentered shoulder pad position helps appropriate balancing of the whole rigComes with a height-adjustable 15mm rods adapter
