Tracking seems rather complicated (but worth learning). The power zoom, however. On an auto focus lens/camera. That's big.
I've been saying this too. Obviously, this is why Alexa Mini, Sony Venice Two Piece (aka the Tethered Sensor Block) and other "camera-in-the-small-box" designs have been created.... Regarding gimbals and smooth camera moves / programmability: $10K+ heavy tripod heads (and cameras) will be a thing of the past soon. Brought this up a while back and folks didn't seem to buy the idea. Now that I have a decent gimbal and seeing the Ronin software for camera moves, it's even more clear that the future of camera control is lightweight robotic control systems with relatively tiny cameras and no heavy tripods or heads ...
You can use the app to setup some basic motion control actions for pan/tilt/roll and repeat the move well enough to do some pretty interesting things like this quick test I did back June of last year with the Ronin-S
Regarding gimbals and smooth camera moves / programmability: $10K+ heavy tripod heads (and cameras) will be a thing of the past soon. Brought this up a while back and folks didn't seem to buy the idea. Now that I have a decent gimbal and seeing the Ronin software for camera moves, it's even more clear that the future of camera control is lightweight robotic control systems with relatively tiny cameras and no heavy tripods or heads. In fact, I can do amazing slow pans with the Crane 2 completely handheld- looks like a high-end tripod head on sticks!
... Unless the Hollywood/movie making industry goes belly up, heavy tripods aren't going anywhere. You have an industry whose best interest is pushing film production as being valuable. At the Hollywood level, embracing large cameras (as main cameras) = work. The larger format cameras create, or rather maintain many many jobs. ...
... Whip pans? How about whip pans with ease out & in!? All possible with a gimbal, and handheld! + the 'ease out/in' is effectively programmable for most gimbals (some gimbals have a Sport Mode to tighten things up)...
If one's product / job depends on large/heavy cameras, time to start planning to pivot to something else- perhaps a robotics startup for cameras or a robotics technician for cameras (people still need to work on these systems + operate them)...
The venice isn't a small camera. Its volume has just been redistributed to multiple areas to act as a small camera. Anyway you think being small is the be all and end all - this is incorrect. If tight space filming is only 5% of a project, needing the camera to be small is quite a specific application. The remaining 95% of the production might require the camera be a certain size to accommodate other crew member's accessories. So while small can help the shoot it can also hurt the shoot.
What crew to camera interaction can't be done wirelessly or via a master cable + breakout?
Did you watch the VENICE video re: camera size + weight and how much of a win the smaller camera was for them? (even with the tether limitation- e.g. still usable with a small drone to 20').
I've been on two features where an experienced Cam Op did handheld with the Venice breakout module and both times the shots had the jitters. It happens because of lack of weight and, more significantly, the sensor plane not being located towards the center of the weight distribution and instead at one end of the weight. Or, more simply, the camera was insufficiently long in length.
Notice that while camera bodies have become more compact, when camera departments build cameras for handheld shooting they aren't necessarily going for lightest weight possible. They still end up building the cameras up to where they are 20 lbs or more. Ops may be glad to no longer have 45 lb rigs, but they also don't want 8 lb rigs. The Cam Ops are not necessarily wanting lightweight rigs but actually like weight at times because it makes for stability in shots. Sort of like having a lot of drag on a tripod. As opposed to a loose tripod head with little drag. An Op is going to be much more steady on a 200mm lens with a heavy camera than with a lighter camera. Increased camera weight= increased steadiness. Decreased camera weight = decreased steadiness.
