Thinking about getting Glidecam 4000...Anybody have any sample footage to show?
FilmBoy77
i'm thinking about getting the glidecam 4000 to use with my hpx 170, anybody have any sample footage links they can show?
what's your opinion on it in terms of setup and stabilization?
My glidecam 4000 pro just came in the mail today. Does anyone know how to work it? I don't understand the loosely handle it keeps swaying everything to one side... I am pretty sure I am not balacrend right.... I used all the counter weights evenly back & front with my hvx200a w/ 1 p2 card. Any Help??
It should have come with folded up directions. Follow those real carefully with regard to balancing the camera on the device.
Basically, you want the stabilizer to hang straight up and down when you hold just the gyroscope handle and let the rest hang. If the camera stays steady and level, you've balanced it right. Use the little screws in the tracks to move the camera left/right and front/back to balance. It takes a little getting used to but once you get it, it's awesome.
Good luck!
Milos
have you tried reading the directions?
stabilizers are NOT something you can just hack your way through. there are a lot of variables at hand. and here, like everything else weve told you about - there isnt a simple "magic formula"
I know it's off balance.... It's all over the place. Should I use all 20 weights? Does anyone know!
Try adding a little more weight - not all 20 (that would be way heavy) but add some more. It took more than I expected on mine, so add in little increments. Those weights are key in dampening the movements, so you want enough so that their effect is noticeable.
The goal should be that when the camera comes to rest, it is sitting atop a perfectly vertical stabilizer. I think in the directions they mention certain tests to make sure that your camera is balanced - practice with those. It's definitely a tough tool to master, but it gets easier as you get the hang of it.
Sorry for the double post, but here's another example:
http://www.vimeo.com/10048512
nice footage man. so there's a glidecam 1000, 2000 and 4000. is there any major difference in these models or does each model just represent the most current one?
dumb question, but were you actually skiing and filming at the same time? how the hell were you right beside those guys following them?
about how much weight do you use on your glidecam to balance it? i have the hpx so i think that's pretty close to the dvx weight.
Well the DVX is 4.2 lbs (additional lenses etc notwithstanding) and the HPX is the same without P2 or battery.
You definitely don't want to go with the 1000, because its recommended only for cameras/loads from 0 - 3 lbs.
The 2000 Pro holds up to 6 lbs - thats what I use now with my DVX.
However, since the HPX with P2/battery is up near 5 lbs, additional lenses and equipment not even accounted for, I would go for the 4000 Pro, which supports up to 10 lbs and isn't that much more expensive than the 2000 Pro.
http://www.bhphotovideo.com/c/product/193814-REG/Glidecam_GL4000_4000_PRO_Camcorder_Stabilizing.html
Yes indeed I was skiing and filming at the same time :) You just gotta go pretty fast and keep up. I had a .66x wide out front so I wouldn't miss too much, and once you get the general feel of where to point the camera, you can just run with it. I guess it helps that I've been skiing all my life.
On my GlideCam I have 8 counterweights on it, 4 on each screw. I probably could/shoud have more, but I've found that this amount does fine and at least saves my arms some unneeded exertion.
I am wondering how many weights do I use. it has the forward/back/left/right adjustments.... I am using the HVX200a all stock - anyone have any tutorials??? I have read the directions 3 times & looked at the glidecam videos on the glidecam website. I need help!!!!
its not always about the number of weights. id be paying attention to the camera stage/plate or whatever glidecam calls it...
