Duke M.
My S-Log arrived and as usually I started playing with it without reading any manuals. It really took me longer to figure out than it should have, so I thought I'd summarize in case it saves anyone else some time. That and there was no manual in the box other than installation in half a dozen languages.
INSTALLATION:
The installation of the S-Log key is fairly simple. The only trick to that is when you’re in the ‘Others’ menu you need to scroll down far enough until you find the ‘Install’ selection.
ENABLING S-LOG:
Finding the setting to turn S-Log on took a little longer. From the Menu select ‘Video Set’ (the third one down on the left) then ‘Dual-Link & Gamma Select’. Then either ‘1.5G RGB444 & S-Log’ or ‘3G RGB444 & S-Log’
CHANGES:
When you enable S-Log a whole bunch of menu items change and a few are added.
MENU ITEMS TURNED OFF WITH S-LOG:
A LUT doesn’t affect dual link output. The LUTs only work with S-Log. They CAN be created with CvpFileEditor v4.20 and loaded into the camera with an SxS card. Only 10bit LUTs are supported. 12bit LUTs won’t work. Four LUTs come with it and you can add 5 more LUTs of your own.
The names of the LUTs are actually abbreviations so you can remember them:
INSTALLATION:
ENABLING S-LOG:
CHANGES:
- TLCS, AGC, AUTO SHUTTER,
- ATW, OFFSET WHITE
- FLICKER REDUCE, FLARE COMPENSATION
- LINEAR MATRIX, MULTI MATRIX
- DETAIL, SKIN TONE DETAIL
- KNEE
- PICTURE PROFILES
- PRESET WHITE (switchable between 3200k and 5600k. That 5600k side button now works the way I expected.)
- BLACK MASTER LEVEL = 0
- BLACK GAMMA =0
- LOW KEY SAT = 0
- 709 (800%) is 800% dynamic range, in ITU=R709, just what it sounds like.
- HG8009G40 is a Hyper Gamma with 800% dynamic range, 109% white output, and an 18% gray card is 40% video output.
- HG8009G33 is a Hyper Gamma with 800% dynamic range, 109% white output, and an 18% gray card is 33% video output.
- 709 (180%) is a Gamma with an 87% knee point and 180% dynamic range based on ITU-R709.
