Eddie B
In Barry Braverman's book, Video Shooter, he has a heading "The Spatial Offset Ruse" which I quote partially here.
You can read the full section with visual aids here.
For the most part, I understand what's being said. I'm very curious about how accurate this is with regards to the DVX100 specifically and some other tips or commentary that the veteren professionals here can offer.
Barry Braverman said:To suppress...artifacts, engineers adopted a strategy of spacial offset wherby the green sensor is offset one-half pixel with respect to the red and blue...
The spatial offset ruse is not without its drawbacks. As a National Geograpraphic shooter, I can recall shooting many high-detail landscapes that contained mostly green tones. Give the spatial offset approach, a large portion of such images as a grassy meadow or rainforest would not be offset and thus subject to substantial artifacts and loss of image quality (Conversely, the same can also be said for images containing very little green, as such scenes would also not be offset and thus subject to a loss of resolution.)...
Shooters with a penchant for capturing high-detail landscapes may want to investigate the spatial offset characteristic of their camera. While the amount of offset is fixed at the time of chip manufacture, some mitigation of the artifacts caused by too much or too little offset may be possible by adjusting the detail level in the camera or adding a physical glass camera filter--two key strategies that should be foremost in the mind of every shooter anyway.
