Anyone using a Gimbal for the FX6? I've been following a thread over at DJI and the FX6 is still not supported for the RS2 (though I know that others seem to have the combination working).
I'm also a bit surprised there is not an adapter out yet to give audio via the IF on the top of the body (that the handle uses).
Nathan
Edit: I see the Zhiyun-Tech CRANE 3S supports the FX9 with the 28-135 Lens but no mention of the FX6 (I have the 28-135 lens as well). Edit 2 nope, looks like with the FX9 "The maximum compatible lens is Sony E PZ 18-110mm F4 G OSS." which is kind of .....
Just a bump to see if anyone is flying a the FX6 on a Gimbal, which one, and how well it works or otherwise.
Nathan
Which Gimbal ?
I've ordered a Zhiyun-Tech CRANE 3S PRO and I'll update on how this one goes with the FX6. I'm hoping with the size and weight on the S3 Pro I may be able to fly the FX6 maxed out with Handle + Audio + the 28-135.
Do people really have that much trouble with white balance? Even when I've been lumped with digital cameras that only give you 3200k or 5600k, or even film stocks at a single consistent white balance, it's really never been that big of an issue. Put a gel on the lights, or a filter in the mattebox.
Nowadays you can literally dial in exactly what you want in 50k increments. Surely any residual issues people were having are sorted now?
The RS2
Cine D have performed their rolling shutter, dynamic range, and latitude tests on the FX6. They tested both internal and ProRes RAW:
https://www.cined.com/sony-fx6-lab-test-external-prores-raw-vs-internal-xavc-intra/
For me, this is the most interesting quote of their review:
"Sorry to say so, but from these lab results I do not see the point of ProRes RAW HQ. It is not supported by DaVinci Resolve, you only have rudimentary controls (exposure & gamma curve, no white balance, no tint, etc….) in Premiere Pro and the files are noisier – to an extend, that even advanced noise reduction in DaVinci Resolve cannot save them. In addition, no highlight recovery options are available."
I suspected that would be the case and is exactly the reason why I didn't waste time covering RAW in my master class. It is sad that some people are going to add 50% to the cost of their camera package (recorder, cards, batteries, mounting rig, etc) and deal with all the hassle of shooting with a Frankencamera for zero benefit. The emperor has no clothes and XAVC-I is a fantastic CODEC. Keep the camera simple and enjoy it.
What about the additional bit-depth and color information?
I did some comparison testing to see whether the advantages of the higher bit-depth and bit-rates shooting Prores Raw (or ProresHQ) were worth it for a feature I'm shooting at the moment. And they REALLY need to be worth it, to put up with the HORRENDOUS workflow required when shooting Prores Raw.
Processed into Prores4444 via FCPX (with it's newly upgraded batch processing capabilities). It's possible to do an accurate SLOG3/Sgamut3.cine transform for the Prores4444 masters. But it's a real pain in the arse.
That said, the improvements in bitdepth and bitrate are pretty readily apparent for any colour grading that requires more than just a few primary adjustments.
And latitude-wise, be aware of the methodology that CineD use in their tests. They're adding no noise reduction to the raw clips (which is why the slightly noise-processed XAVC footage, yields slightly better latitude results in their tests). But you can 100% pull out more shadow detail from the transcoded raw footage, than you can from XAVC footage. It's not a huge difference by any measure, but if you're zooming in 400% to compare the two, there's clearly more you can salvage from the thicker footage (if you apply a bit of noise reduction in post judiciously).
The workflow is still awful though. So I find it hard to recommend.
