I really have no idea. Did you try the export for web feature that QT Pro has? It won't be an H.264 file but it will be small. Then maybe you could convert that file using H.264?
I don't use a mac, so take this as you will, but....
You mentioned a slider and a bit rate. For me (on a pc in procoder express which is basically using quicktime pro) If I "restrict to" a bit rate, the slider becomes non-functional.
You *should* be able to quite easily render something with a bitrate of around 1060 if you have decent audio settings and it should come out at right around 48-49 megs for a 6 minute film. I used mp4 audio, but it appears that a couple of folks who used this audio choice on a mac are having problems with their audio not working on pc's... So, you might want to stick with Michael's audio suggestion...
But, maybe there is a check box or something that you are missing. For me, it's either or concerning the slider or selecting a bitrate. Not both.
Maybe, if all else fails you can send your 100 meg file or whatever to someone and they can re-encode and upload for you?
Just throwing out some stuff for you in case any of it happens to stick...
you know the funny thing about the early morning shoot is that we got the best shot half way through. Unfortunatly that shot was the one casualty of the 6 minute time limit. I got everything else I wanted in.
