the orchid
wow, looks great.
How do you find the crane? Does it just barely support the weight of the AF100? Can it stand much more? What are your experiences with the remote head? Pros and Cons?
I think you don't want to put anything heavier on that crane. You can do it if you don't use the middle bar and that gives you a smaller jib/crane and easier to work with albeit not the full range of movement. The motorized head is good. Some tweaking with having cables running smooth while rotating the head. It's fairly easy to move the crane and use the remote at the same time. Used gently it does give you smooth action but a double bar crane is more rigid and thus smoother when moving quicker.
I have to try how much wind it catches outdoors this week.
