The old 1000w movielight: Are their new alternatives?
Joost
Many of you will know this lamp. It is cheap (10-30 bucks) and a exelent light source. I am looking for an alternative (I know it will not be cheap as this one).
I love the light it gives, it creates awsomeness. Their are ton of uses for it, and I especially use it to let subjects pop out of the shadow in outside scenes.
The dark side of this light is that it gets superduper hot. I am a little (very much) afraid of it :)
1- Im afraid it will couse fire some day.
2- The whole crew gets sweaty when it's on for a few minutes.
3- It has a big power consumption.
4- You smell the burning of the dust in the room.
I would love to know who knows some alternatives for this lamp wich do not have this side-effects.
-I'm prepared It will not be cheap, but still would like to know the cheapest options.
-1000w light eq
-Low power consumption and heat production (LED, PL?)
-Portable (very good spec of this lamp to)
-day or tungsten col does not mater so much for me.
-Bundled light (is that called spot?)
I'm curious.
That's a Lowel V-Light. I've got a few of those kicking around in one of my old light kits. Visit their site and see if they have anything which peaks your interest or gives you ideas.
I have a few of those, and typically use them through a silk or umbrella or to light up white/green backgrounds (since they spill everywhere anyway). Truly a portable powerhouse, nice paired with some Lowel Pro-lights for mobile work. I think they're actually 650W. It's kind of its own beast that I'm not certain they've replicated in LED-form - there are a number of LED fixtures that might yield a similar wide spread, but LED tends to fall off much much quicker... maybe a good or a bad thing depending on application.
Just make sure its always on a secure stand, never let anything (except maybe gels/clips) touch it while in use, never point it down (it will melt itself), give it time to cool after a shoot and always pack some heat-resistant gloves in your G&E bag.
You can find used rectangular theatrical lights that use the "work light" bulbs, can be lamped from 100 - 1000 watts, and have nice barn doors. You'll never use an overpriced Tota again. Bulbs are cheap and easy to swap.
But that won't solve your heat problems or power draw issues. The cheapest source of 1k of light that's cool and low-amps (if ya ask me) is a quad biax flo unit. There are chinese versions for $200-$300. They put out 1k of nice nice daylight, without gelling, and you can get tungsten tubes for them. A couple of those and several dual-biax (cheaper) kicks out a LOT of light, little heat, and you can run a ton of 'em on household power. I own all chinese (no Kino's) and they're going strong for years.
Here's a pair on Amazon for around $400.
They are broad soft sources though - if you need something aimable, check out cool lights' 150 watt CDM fresnel - puts out about 650 watts daylight equivalent. Or just buy the bulb and ballast and convert some old fresnels (that ballast is expensive at $300, I'm going to try that bulb with a cheaper electronic ballast this summer - it's a great bulb). They also sell a 3" HID fresnel that's about 300 watt equivalent.
You can use a 1k par or fresnel with full CTB to mix with the above stuff - often just 1/2 CTB looks really nice, a bit warmer. Really wasteful though, the full CTB kills a LOT of light.
Alzo sells 150 HID lights that I use often. They're a little rickety but very bright, about 600-700 equivalent, and it's clean, no-minus-green needed 5500k. They also sell a bulb & ballast combo that's just handy as hell for under $150 (think China balls). (They also sell a cheap pancake lantern that's great with those). I converted a fresnel for this setup but it wasn't killer light output since fresnels are inefficient and the bulb is a frosted household style - Cool Light's bulb is a true "projector" style bulb that works great in a fresnel. I'm thinking of converting a Flexipar for one.
From there it's used HMI, a 575 or 1.2k will run on a house circuit. Next step up would be the chinese HMI knockoffs (many people reporting they're coming around on quality and are a good deal if handled gently - not for rental houses). From there it's the cool lights 575 HMi fresnel or 1.2k par (about $2 & $3+k but a great company). And then up to Arri, etc for the big big bucks.
Thanks for the awnsers. I have many lights and found out the old movie-light might be inreplaceable because of the aim and bundle + the brightness and low falloff.
I have 5 construction-lamps, 3 320w PL, 2 Coollight PL, 1 620 LED. When I expand my Kit I think it will be 3 1008 LED so that I keep it cool and portable.
