Good work, I'll be interested to hear how that works out. Piher makes a variety of potentiometers, as seen here:As an update for anyone who has the 521 and would still like to make it work fully without adding a pad cable, I've found a supplier of the Piher pot that lives inside the unit and controls the iris. They're going to send me a 25K version (24 not available) and I think that should do the trick - it means that you'll get a true 0 ohms at the botom end and a bit more than you need to fully open at the top end.
http://www.tawelectronics.com/piher_potentiometer.htm
If you know the Piher model number, we can find out how its precision is rated. Most potentiometers' max resistance is rated at +/- 10-20% of their nomimal specs. In addition, the sensitivity of each AF100's remote control circuit can vary over a similar range. The max resistance of my 521PFI unit measures 20.8K ohms, which is 4% higher than its nominal 20K specification. This particular unit works properly on my AF100 with all supported MFT lenses I've tried. If the precision of the 25K Piher pots is no worse than 10%, they should all have at least 22.5K resistance.
