Hrrrmmm....
rogar-Kriz(DBG):
Nice pic! Seems familiar.:laugh:
It looks like one of those 35mm adapter rigs. We're back in time.
A man gets lazy typing from his phone! :thumbsup:
On the plus(?) side, at least it's in a single united package which sits inline with the camera on rails - so balancing it hopefully won't be outrageous.
This is I guess a 4K solution, but it's not really practical is it? I think someone else mentioned it, but it is remarkable that this is an 'upgrade' plan that's been designed and planned by a single company. If there were multiple third-parties being used to prize 4K out of the FS700 then an unwieldy beast like this isn't all that inconceivable, but that it's all Sony is a huge disappointment.
Almost as if they don't really want FS700 users shooting 4K in the first place!
those cameras won't be able to do highspeed until nearly 2014. the F55 won't even be able to do any onboard 4K XAVC recording until September of this year! talk about bait and switch. now THAT is some false advertising.
Hey Dylan, remember the FS700 is an 8-bit 800h x 1000v x 1000 diagonal line resolution camera which also exhibits aliasing here and there. The F5 is a 10-bit presumably 1000h+/1000v+/1000d+ camera with internal support for high bitrate 422 10-bit LGOP MPEG2 as well as the new XAVC H.264 codec + 444 SR MPEG4, and we'd also expect better aliasing performance (as in little or none). The F5 is built more sturdily and along with many other features makes it a clear upgrade from the FS700. For 4K it will be 16-bit vs 12-bit for the FS700. Consider that "4K" really just means > HD. With the exception of the F65, none of the "4K" cameras can sample and deliver 4K resolution. Thus the FS700 might be something like 3.2K, the F5 could be 3.6K (making up that number), and the F55 3.8K (made up number), leaving the F65 with full 4K (even then, not quite, but not even RED (5K Bayer array) can match the F65 (8K Bayer array) at this point).
Coming from a 5D3, the FS700 with a Speed Booster (+ Nanoflash for max quality work) was an excellent upgrade. Being able to use Canon L lenses with a full frame FOV is very cool, finally with decent resolution compared to the 5D3 (which is fine for close up / people shots). Pro audio directly in the camera is excellent (really like the adjustable from shotgun mono to wide stereo performance of the Audio Technica 4029 Mid-Side mic. Nice not needing a Sound Devices preamp or recorder (haven't compared yet to the preamps in FS700, but so far the FS700 sounds great)).
Back to the 4K topic for the FS700- I think if I had a budget for a project that needed/required 4K, I'd want 10-bit and perhaps even RAW (whicah the FS700 could provide at 12-bits). Shooting 4K to crop/zoom to HD to allow for creative post work would be cool, however we'd need a true 4K image to start with, otherwise the final result will be softer than full HD.
Renting the Sony 4K gear or buying/renting a third party solution might be the way to go.
