Is there really any difference between these 2 cameras, that makes one superior to the other, other than the fact that one uses SD cards & one uses P2 cards? And other than the tape deck on the HVX?
Also, a question about SD cards vs P2 cards: If I'm not mistaken the big advantage to SD cards vs P2 cards, is that they are cheaper, they hold more data and thus you can buy more, basically eliminating the need to offload on site. Am I correct?
And to just go a little deeper on SD cards regarding offloading and editing using Sony Vegas: Are you going to run into the usual headaches with SD cards as you do with P2 cards when you use Vegas? Such as needing the Raylight middle man?
Is there anything else I need to know when comparing and choosing between these 2 cameras?
