Thank you very much everyone for the feedback, espically Butcher, Jim2000, mcgeedigital, milksac, and grinner. I apreciate it so much ...:dankk2:
mcgeedigital .. thanks alot for your advice to stay away from VelocityHD.. and thanks for the links, but, why people are dumping Avid's systems if you are recomending them?!!
Sorry I don't have much high end "hardware" experience but sounds like Butcher knows what he is talking about
I'm a windows person too but my next computer will be some type of mac just so I can edit with FCP.
I really like Premiere UI and ease of use. Not to mention I love the Dynamic Link between adobe products. I use after effects etc.. a lot.
I'm sure many more will tell you a lot of clients do care about your NLE. I think they should only care about the final output as well but that isn't always the case.
Keep in mind the CineWave (flagship system for FCP) died after Avid bought out Pinnacle Systems.
Bad Avid!![]()
No different than Apple buying KeyGrip (from Macromedia, I believe, with a PC and Mac version) then renaming it Final Cut Pro and killing the PC version. It's just business--develop or buy the technology you need and try to keep it from helping the competition.
Regarding clients and the edit system you use--you're right, it shouldn't matter. Unfortunately, edit systems have gotten so cheap that producers and clients are buying their own to play with. That means they want someone who has a compatible system so they can rough cut then send it on, or even try to finish the piece then hand it over to fix their mistakes. Plus, perception is everything.
None of our clients even know what editing software we use, and we don't tell them because they don't care. They just want a quality product that sells their product or brings them customers. How we get it done doesn't matter, as long as it's good and within budget.
Michael
It's an option you can turn on. See:
You can add a Filmstrip across the top that shows a general thumbnail representation of your footage, and you can turn on clip thumbnails that show the head frame.
Michael.
Michael
I think you're overstating the importance of this feature. I don't see the value in looking at some tiny thumbnail image in the timeline to try to navigate my way through the material. Heck, I can look at the record monitor or an external monitor and see a large image of the same thing without having to squint.I do not understand .. I mean this feature is very important, and makes editing very easy!
If I need to look at the timeline and quickly recognize different segments in the program I'll color code the clips in the timeline. That way I can easily see where the segment breaks are - again, no squinting or zooming into the timeline required. The other tool that's useful is the locator tool. Locators are sorta like bookmarks, you can quickly move to sections of the timeline quickly with locators. You can also add notes to each locator.
There are tons of tools available in all NLE's, the trick is to find the ones that speed up your work flow.
I forgot to mention... I learned that Avid's NLE are a littel hard to learn, so, is there any demo version for Media Composer, or Xpress Pro for instance?
THanks
just got avid symphony nitris, real time full hd on hd-sdi. realtime color correction, realtime universal mastering. we use 8 core machine with iscsi 10gbe connection. easily handles 6-8 streams.
Thanks .. I am considering it very seriously. With 8 core you get 6-8 HD streams .. dose it make a difference if using 4 core or 8 core in the HD performance? I mean dose symphony nitris depends on its hardware for RT performance, or on the host PC, or both?
