Text looks great in After Effects...jagged when imported into FCP
take2visualmedia
I can't figure out what's going on here. I have a 1920x1080 timeline in FCP, Apple Pro Res Codec. Create text graphics in AE....render them out in Animation Codec (I tried Pro Res too with same results). I bring text into FCP and it looks bad.
If I play the file in Quicktime, it looks great. Looks just as great in AE. Bad on FCP....viewing on an external monitor. Any ideas?
...if I bring the graphic file from Quicktime into it's own sequence in FCP it looks perfect. Just not good in the sequence I need to work in which is the same 1920x1080
Is the footage interlaced? You can set the FIELD DOMINANCE to NONE in the Sequence Settings and see what that does.
Hi Shane. No the footage is not interlaced. Sequence is 1920x1080 30p ProRes 422. File from After Effects is coming in Animation codec...seems the the degradation happens when it transcodes to PreRes for the Sequence. If I put it in it's own timeline, at it's own settings in FCP, it looks as it should. Problem is I can't really have a sequence in animation codec. If I was only going to output to a file this would work because it compresses fine but I need to put out to tape for some broadcast outlets.
Select your jagged text video clip on the timeline, go to info (right top corner) of the clip, choose "progressive"... that should solve it. I just did it.
