[FS: General] Teradek CUBE 120/320 HD-SDI Encoder/Decoder with RED PROXY RECORDING
cartmen789
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=220768130835#ht_1047wt_1141
MAKE AN OFFER
The kit is in perfect condition.
Total Value of kit is $4862
Includes
CUBE 120
CUBE 320
Cable - Cubits 418 - 18” Red Lemo to Lemo ($100)
Cable - Cubits 218 - 18” lemo to 4 pin XLR ($100)
RED Proxy Record License ($900)
Cube-120/320 features HD-SDI input/output and WiFi or Wired Ethernet input/output. Need more information? Visit the Cube Webpage. Need more information? Visit the Cube Webpage.
Cube™ Encoder/Decoder pairing is the ideal solution for turnkey on-set video monitoring. Use the Cube Encoder to stream HD video over WiFi, then connect the Cube Decoder to a small hand-held monitor or a professional field monitor to receive the signal and view video up to 1080p24.
Simple Setup
Cube's web interface features a Setup Wizard to simplify configuration. After connecting video and powering-up Cube, create a network, logon to Cube's web interface, complete the Setup Wizard, and begin streaming video.
Advanced Compression
Cube uses H.264 High Profile (Level 4.1) video compression, which is the most advanced compression algorithm in the world today, and it features a built-in scaler to convert from 1080 to 720, 480 or 240 resolutions. Users can choose a resolution and target bit rate based on the availability of IP bandwidth. Typical bit rates for HD are between 2-4Mbps, and SD bit rates are typically sub-1Mbps. Cube's end-to-end latency is approximately 1/8-1/2 second.
Small Size
Cube is tiny (about the size of a deck of cards), uses only 2.5W of DC power, and weighs only 7 ounces, and mounts easily to a rail system, cage, hotshoe, or camera baseplate. Cube's line-of-sight WiFi range is approximately 300 feet when used with a high quality WiFi access point. Cube has been tested extensively with RED ONE, Arri Alexa, Panavision Genesis, Canon 5Dii, Canon 7D, various handi-cams and more.
