BobDiaz
The Professor
A man with one watch knows what time is, but a man with two watches is never quite sure. When you have a single number, the number seems correct, but when you have two or more numbers that don't agree, you have a problem deciding which is correct. What follows is a listing of the different parts to the model I've tried to create to resolve the issue as to what is the native resolution of the CCDs.
IT HAS TO BE THIS LOGIC:
This logic assumes that the camera just has the minimum amount of pixels to resolve the highest resolution. The highest necessary resolution is 1920x1080 or if you take into account the 1280x1080 recording resolution, it's a bit lower in the horizontal resolution. Assuming that everything is pushed to the limits, the Kell Factor could be as high as 0.95 and the increase in resolution due to pixel offset could be as high as 1.7; resulting in a somewhat fuzzy maximum resolution.
IT HAS TO BE THIS LOGIC, FOR COLOR:
Assuming that the 4:2:2 has enough color pixels to fully resolve this ratio, we find that for 1920x1080, 1/2 of 1920 = 960 pixels in the horizontal direction. On the other hand, the maximum recording resolution is 1280h, so 640 pixels will cover this nicely. I think that it's a safe bet than the native CCDs are greater than 640 pixels in the horizontal direction.
As for the vertical direction, some have suggested that the vertical native resolution is 1080. While I can't fully rule this out, 780h x 1080v is possible, it seems a stretch. A native resolution of 720v is also possible.
Before someone starts throwing rocks at Panasonic, remember this is ONLY SPECULATION on my part and NOT fact. If I am correct, remember that 1080 4:2:0 would have 540 color samples in the vertical direction. Any number of color pixels greater than 540 is better than 4:2:0.
An interesting experiment would be to take the JVC, Canon, Panasonic, and a Blue object in front of a Green Screen. First take the component output of the JVC and record it into the Panasonic at 720p. Now record the Panasonic in the same 720p mode. Do the vertical color edges look the same between the two clips? If the look about the same, we know that the vertical native resolution is at least 720 in the Panasonic.
Likewise, do the same with the component output of the Canon into the Panasonic recording 1080i mode. Now compare that to the Panasonic camera's recording at 1080i. Do the vertical color edges look the same between the two cameras? If the Panasonic looks worse, we know that the vertical native resolution is less than 1080.
Until someone does this experiment, I can only guess at what the results might be. However, if someone does it, I'm sure we'd all be interested in the results.
CCD SENSITIVITY:
As the surface area of a single CCD cell increases, so does the sensitivity of the cell. If you double the area, you double the sensitivity. "IN THEORY", one should be able to look at the relative sensitivity of each CCD and have a rough idea of the number of pixels.
The Effective ISO rating is found in Adam Wilt write-up.
See: http://www.dv.com
Canon XL-H1 200 ISO (1440x1080=1,555,200 pixels)
JVC GY-HD100 Just under 320 ISO (1280x720=921,600 pixels)
Panasonic AG-HVX200 320 ISO (???x???=???,??? pixels)
Panasonic AG-DVX100B 500 ISO (770x492=378,840 pixels) The DVX-100B was not reviewed by Adam, but I added it to the list for comparison.
Sony HVR-Z1 200 ISO (960x540=518,400 pixels) I Corrected for shutter speed difference in the Sony.
If we take the Canon's resolution and ISO and compare it to the Panasonic's ISO, we get a ratio of: 1,555,200 pixels x (200 ISO / 320 ISO) = 972,001 pixels. This looks VERY close to, but a bit higher than the number of pixels on the JVC.
Using JVC's resolution and ISO, we come up with a native resolution slightly LOWER than the 1280x720 resolution of the JVC.
Using the Panasonic DVX-100B for comparison, we get: 378,840 pixels x (500 ISO / 320 ISO) = 591,938 pixels.
If I compare to the Sony, the numbers don't make any sense: 518,400 pixels x (200 ISO / 320 ISO) = 324,000 pixels. A 720x480 CCD has 345,600 pixels. I can only assume that the Sony used an older CCD that was not as sensitive to light as the current CCDs.
Using this type of logic, the native pixel count could be from 972,001 pixels to 591,938 pixels. If we assume a vertical resolution of 720, the native resolution would range from 1350x720 to 822x720. I'm not saying that it would be those exact numbers, but could be something around that range.
BEFORE anyone starts saying that this IS the resolution, remember that CCD sensitivity varies a great deal and surface area of the pixel is only one of several factors that effect the sensitivity. This part of the model, can only give us a very rough idea of the range.
SINGLE OR DUAL A/D (Analog to Digital):
We know that JVC had to use dual A/D converters, because 1280x720 was just too many pixels to transfer from the chip in serial. That came to 921,600 pixels per 1/60 of a second. Splitting the CCD into a left and right side allowed for a slower shift clock, but required dual A/D converters.
Canon, as far as I know, was able to do this with a single A/D converter. Thus, with 777,600 pixels per 1/60 of a second, a single A/D Converter per CCD is possible, but with 921,600 pixels in 1/60, a dual A/D Converters are required. The maximum number of pixels BEFORE one must use dual A/D Converters is unknown.
This suggests that the number of pixels on the Panasonic CCD is likely to be less than 921,600 pixels. Maybe Panasonic did have 921,600 pixels and found a better way to transfer the data from the CCD.
IF we assume that the number of pixels is exactly 777,600 pixels, and the vertical resolution is 720, the Native CCD Resolution would be 1080x720. This is just an example and should NOT be taken as an exact number.
What this part of the model does suggest is that the upper end for the Native Mode Resolution can NOT be 1350x720 or even 1280x720, but the lower end of the CCD Sensitivity might be possible. Thus, something around 1080x720, 1024x768, or 960x810 may be reasonably close to the Native Resolution.
AIRY DISK MEASUREMENT:
My thanks to the Masked Engineer a well-known television engineer who wishes to remain anonymous for pointing this one out:
http://www.tvtechnology.com/features/Masked-Engineer/f_mario_orazio-08.17.05.shtml
In theory, the following constants should be applied to the following colors:
If this logic is correct, than the JVC's resolution should take a major hit when tested at F16. A French WEB page reported 550 lines, but the calculation says, 4791 (Blue) / F16 = 299 lines. Clearly, the logic is flawed.
The Airy Disk does NOT have a hard edge, so we would need to test cameras like Canon and JVC where we know the CCD resolution at different F Stops to see the impact of the Airy Disk and THEN compare to the Panasonic.
More tests would need to be performed before I can even begin to use the Airy Disk as part of the model.
RESOLUTION CHARTS:
Depending on how you want to read the resolution charts, the numbers range from 700h to 550h and 750v to 540v. The range of numbers can drive you absolutely nuts. Just assume that the correct resolution is 600h and 600v. This is not he lowest number, but is within 50 to 60 lines of the lower numbers. This translates to 600/700 of JVC's Resolution of 1280x720 or an effective resolution of 1097x617.
Taking into account the pixel shift and the difference could range between 1.2x to 1.5x increase in resolution. This would take our 1097x617 effective resolution and make the native range from 731x411 to 914x514. These numbers seem way too low to make sense. IF they were correct, going from 720 mode to 1080 mode would offer no real increase in resolution.
At the high end of the scale, the numbers are 700h x 750v. This would be an equivalent resolution of 1280x771. With a native resolution ranging from 853x514 to 1067x643. The resolution 1024x576 seems like a good number using this logic.
The flaw is this part of the model is the numbers vary too much AND we must assume that the CCD is the limiting factor for the resolution. Given that the Canon's maximum is around 800v lines, when the CCD should go to around 1000, this suggests that the lens could be the limiting factor.
CONCLUSION:
If you take only one part from this model and use it to obtain an answer, you ignore all the other parts and fool yourself into thinking you know the answer. My wife knows the answer to, "What time is it?" Several year back, when our watches didn't agree, she told me mine was wrong. When I pointed out that I check my watch every month to the National Bureau OF Standards WWV's Time Signal, she told me, "They're wrong too!" Maybe I should ask her what the Native CCD Resolution is... :cheesy:
Bob Diaz
(0.95 Kell x 1.7 Offset Increase) = 1.615
For 1080 mode:
1920 / 1.615 = 1189 Native CCD horizontal or
1280 / 1.615 = 793 Native CCD horizontal
1080 / 1.615 = 669 Native CCD vertical
For 720 mode:
1280 / 1.615 = 793 Native CCD horizontal or
960 / 1.615 = 594 Native CCD horizontal
720 / 1.615 = 446 Native CCD vertical
These numbers represent the limit for the lowest native CCD resolution. A more reasonable guess would be to use a Kell in the range of 0.6 to 0.85 and an offset increase of around 1.2 to 1.5 times. I could show the calculations, but this does not prove anything.For 1080 mode:
For 720 mode:
CCD SENSITIVITY:
Red = 3613
Green = 4661
Blue = 4791
Color Constant / F Stop = Maximum Lines Of Resolution
We know that the HVX-200 holds the resolution to F8 and at F9.6 the resolution starts to drop. Thus, 4461 / 8 = 558 lines, right? No, WRONG!!!! Green = 4661
Blue = 4791
RESOLUTION CHARTS:
CONCLUSION:
Bob Diaz
