To be clear, ı can not reset to my hvx TC,it come back from a shooting today and will go for another one tomorrow,but i can not reset the time code for tomoorow.What is the easiest way of doing this?
If you mean using the TC reset button on the side panel of the HVX, the only time that button seems to be active for me is when I go through the menu to Record options>TC Preset
When the window allowing you to change the TC shows up you can then press the TC Reset button to zero it out quickly. Then simply push ok to save the preset and your TC should be back to 0.
If your TC is Rec Run it will only run up when you press the record button, if you set it to Free Run it will continuously run throughout the day even when not recording.
