scorsesefan
Thinking of buying one of these for recording talks/concerts and plugging into the house mixing board. Does it have a pad? Can you monitor levels? Any thoughts?
I've had a DR-40 for quite a years now, but don't ever recall using the internal preamps. They probably sound 'ok'. The external mics are decent for high SPL room/ambient sounds (my primary use). The mic pres on the DR-680 are 'decent'. Don't know if they're the same in the DR40. As I've stated, the 680 is one of the few recorders, that bypasses the mic pres in line mode. Again, I'm not sure if the DR-40 has this feature.. I kinda assume not, but sound fed from a pro console is pristine.the DR-40. I know it's fine for recording a line in, but are the mic pres acceptable for external mic recordings?
What common cables/accessories should we be carrying in order to take a feed from a sound board and record with a Tascam (DR-60)
