listen, i've looked everywhere on this site, and i can't find too much info on issues with tape brands, or at least enough to answer all of the questions that i have. but this seems to be a common problem, maybe someone could put up a sticky guide on this?
here are my many questions, any help is appreciated:
1. can mixing tape types in a camera cause any PERMANENT damage to the heads? is a cleaning all you need to do to correct this?
2. how do i know which tapes are wet and which are dry?
3. whats the difference between a panny mq tape and a panny pq tape?
4. what should i do if i've got a deck/camera that's recieving all different types and brands?
5. are cleaning tapes really THAT harmful to a camera? what if i use one on a camera besides my dvx, perhaps on a deck that's recieving all different types and brands? again, will it leave behind any PERMANENT damage?
6. can a tape that's run through a deck/camera that's been using other various brands of tapes actually transfer anything into my dvx? is a tape basically ruined after running it through a dirty deck/camera? can you clean a tape?
7. how much mixing of tape types does it actually take to make a noticeable difference in quality?
8. if i were to only run my tapes through the same dvx, would it still be risky to tape over old footage?
9. can i use the same cleaning procedures from the tutorial on other cameras/decks?
thats all i can think of at the moment. thanks for the help. you people are what make dvxuser such an excellent resource
