steve phillipps
Any idea whether the Odyssey 7 can get variable frame rates out of the Varicam - the Nanoflash can do it with Crank, wondered if the Odyssey would be a good choice for the old workhorse?
Steve
Steve
Thanks Mitch - so what could I actually do - is there a crank function like in the Nano so that I set camera to 60fps and control the recorded speed on the Odyssey? Or does it just retain flags so you import into FCP and use the frame rate converter?
Cheers,
Steve
No - what comes out of the SDI is not DVCPro - it's uncompressed - it's simply 60 frames of 720 material. The Nano takes in those 60 frames and bins the ones it doesn't need (more or less). Same would happen in an NLE - you take in all 60 frames and the programme can be told to just use say 25 of those every second or whatever it needs. Or use all 60 frames at 25P and you get slow motion.
Steve
This is the thing I'm talking about:
https://documentation.apple.com/en/finalcutpro/professionalformatsandworkflows/index.html#chapter=3%26section=4%26tasks=true
Theres no indication it will work with anything other than DVCProHD but maybe it does?
Freya
Flagged frames, aka VariSpeed, is available on a number of cameras, including the ARRI ALEXA. The Odysey7Q records with VariSpeed as well. The signal can be 60p coming in, and this is auto-detected so that every frame is always recorded. But in our menus one selects frame rate and either "follow camera input" or a different frame rate, such as 24p. When the files are played back they will do so at that frame rate with no additional work.
It records every single frame and also notes the frame rate you wish to play it back at. But every single frame is captured.So it gets the 60p or output but records whatever frame rate it really is?
Sounds great!
Let us know if or when the Odyssey 7 supports 720p!
Freya
