I posted this question at the AF100 forum and then realized I probably should have posted it in the audio forum.
Hope I'm not breaking any rules by posting the same question in two forums.
I use an FP33 to feed audio to both the camera and an Oade modified DR-100. The FP33 is close enough to the camera position that I could monitor audio at the camera by either plugging headphones directly into the AF100 or by using a tape return to the FP33 and monitoring audio there. Other than the flexibility of being able to monitor either the FP33 or the camera audio when using tape return, are there other pros or cons for either option that I should be considering?
Thank you.
Thank you.
