Tamron 15-30 2.8 VC - Hoping it work with the speedbooster!
pythonman
The recently announced Tamron 15-30 2.8 VC looks like a great super-wide lens for handheld or gimbal use. If this will work with the speedbooster we're talking a F2.0 15mm (full frame size!) lens with image stabilisation!
Here's about the only useful video review I could find, although no testing was done for use with video:
www.youtube.com/watch?v=fbs4VYlkMjM
Will keep a look out for more details as it's released.
The flare control is impressive, which is my only complaint with the 14-24. Well, filters would be nice...
It's too bad about the lack of filter threads for NDs or Grads (which isn't uncommon for ultra-wides I suppose). Less of a problem for an FS700 with built in NDs but kinda a pain for other cameras without them
That's partly why they invented matte boxes.
I definitely don't disagree with you, a mattebox would be one solution, although vignetting is always something to watch out for @ 15mm on a 35mm sensor. But whether for handheld or gimbal work, I think some (maybe not all) people will find that a real pain to be tied to always using a matte box. Hell, I didn't even like being forced to use screw on ND filters all the time with my FS100, let alone a mattebox.
I have an a7s that I like to use for glidecam work rather than my FS700, but once you throw rails and a mattebox on the a7s, you might as well be using the fs700 w/ internal NDs. Obviously if you are ok shooting at f16 and you aren't clipping anything, NDs might not be needed.
Regardless, I suppose there is always the Canon 16 35 f4 IS if people need image stabilization and filters. Good to have choices!
Yes, that lens would be one of my other choices. I will wait to see if the Tamron will successfully work with the speedbooster before I make a decision.
Hey guys, I know this is an old topic, but I am about to buy tamron 15-30 and I want to use it on fs700 with speedbooster. Does anyone tried this combo? According metabones website it should be fine, but I would like to know if someone has this.
speedbooster ultra + a6300 + a7r2 and it works well, though make note, I am not sure if it is my lens specifically but my image stabilization jumps a lot when it is on the monopod or Ronin. I've sent the lens in to Tamron and they have said that there was nothing wrong with the lens so a bit dissapointed on that front. Other than that it is a decent performer (especially if you have NDs in the body/adapter).
After my experience I would not recommended combo tamron 15-30+speedbooster+fs700. Not sure if I got a bad copy of tamron or speedbooster but I have pretty bad issue. On 15mm at 2.8 (2.0 with speedbooster) I am not able to focus to infinty. When I stop down to 5.6 lens is sharp as hell. I have tried it on my a7s and it is sharp on 2.8. If I use nonspeedbooster version with fs700 it is sharp as well on 2.8.
Anyone suggestions? Could be my speedbooster f*cked up? Or lens? I don't have any issues with 24-105.
So I have found the problem (probably). It is speedbooster. Inner element moved. Screw holding inner element is damaged. Anyone has experience with adjusting speedbooster and replacing screw?
btw: I have bought speedbooster from guy here, now I know why did he sell it:).
