system settings being recorded
bringuet
Hi, have made a change to my new hvx200 that records viewfinder info to recorded video, mistakenly, of course, but can't find my way back there
anyone know which menu pick/label that'd be?
or, barring that, can I set everything back to
'factory default'?
thanks
b
It won't actually overlay the data onto the video, any recorded information is kept in the subcode area. You probably changed the menu item for "camera data"; try going to the MCR mode and turn the thumbnails off, then bring up the menus and look through the "display setup" menu.
barry, am using a citidisk hd, at least until my firestore arrives, no p2's & no tape.
have download footage to a laptop & the OSD info is definitely there.
was perusing the manual & noticed a carefully worded mention of what I might have done on page 112, video out osd: 'bear in mind...'
thanks
b
Yeah, that's there too, forgot about that. The OSD is on during non-recording time, but with the CitiDisk you control recording externally, so the system wouldn't know to turn off the OSD.
Oops. That's really bad; looks like a standing recommendation would be that if you're going to use a CitiDisk or FireStore you should always always make sure that VIDEO OUT OSD is set to OFF.
Looks like it's only a problem if you have the switch set to "tape" mode. Try moving the switch to "p2" mode and you should never have the problem again, I think.
