SYSTEM FREQ question
ASG
I have an AF-102 (PAL region). When I set the SYSTEM FREQ to 59.94, it says "cannot be used due to incompatible data". Does this mean the AF-102 is restricted to 50Hz use?
I have the operation type set to film cam, rec format ph 1080/24p, but I can't seem to get any settings to work in 59.94Hz mode.
Thanks for any tips.
** EDIT - OK you can't have 50Hz and 59.94Hz clips on the same card, and you have to format the card while in the freq that you want to record in if it was formatted in the other frequency. A little inconventient. Feel free to delete this thread.
