I noticed that when I set the value to 000 for syncro scan in scene files, it created an old school film flicker effect outdoors or where there is a lot of light. It initially came up with a value of 1/00.0. When adjusting the syncro scan in cam, if you move the joystick to the left, you will see more speeds above 1/249.9. I saw weird shutter speeds of 1/566.1, 1/476.1 and even saw a speed of 1/17.6 but it did not produce a slow shutter effect. Once you get back 1/249.9 it defaults back to normal syncro scan speeds and you have to re load the scene file. You can get more speeds by setting 1,2,3 and 4 digit values such as, 003, 1002, 2001, etc. Play around with numbers and see what you get. I know film flicker can be done in post, but I think this is pretty cool to be able to do in cam. More things may be possible with this cam than we think.
