sync issue 720/30PN @ 24fps..
Steadiguy
I'm hoping that someone has done this before and has an solution! We did a multi-cam show and one of the cameras was set @ 720/30PN @ 24fps. Now we have footage that we can't sync because it 20% faster. We are cutting on a Avid Media Composer 2.8 and I'm hoping there is a way to fix it. Does anyone have any possible solutions?
K.Smth
Try to dump the frames out as TGA/TIFF reassemble into MOV @ 23.987 regular speed, doubling certain frames into 30.
EDIT: But now that I think about it. I think you're SOL as it discarder frames on undercrank so the right speed footage will look like 12fps or something.
Could you import into a 24p project maybe forcing out the 30pN in the equation.... then interlace the footage from 24p to 60i with 2:3 pull down, export to a 30p project.... then deinterlace the 60i to 30p?
