sync dvx100b and hvx200 / and using standby mode
ajwwong
I read the bit in http://www.dvxuser.com/articles/sync/ about syncing hvx200 and dvx100b.
I assume this means that I shouldn't put the cameras in "standby" mode -- i.e., where the camera goes into standby after 5 minutes of non-use, because then the only way to get it out of standby, as far as i can tell, is to turn the camera off and then on again... and then you'd be out of time code sync, right?
Thanks.
Appreciate the help.
Albert
