davidcheok
Has anyone tried this for a lower cost solution for field backups and extending the life of the SxS instead of the adapters/SDHC method?
NEXTO Extreme 2725 + 320GB HDD
Sony SBACUS10
Battery pack (2x 6v DC) required to power reader/LiPo 3.7V 2200mAH single cell for 2725
My issue was this.. I have 3 Sandisk 16gb SxS and the Sony 8GB SxS. To extend the possibility of working in remote locations e.g. deep in the rainforests for a couple of weeks away from civilisation and power, i needed a relatively low volume and weight solution to increase recording capacity within a affordable budget. I researched long and wide into viable solutions and this is what I came up with. Lets look at the alternatives first.
A few SxS cards + Laptop
Pros -
Full feature set
Field Review/Edit
Cons-
Big footprint/weight
High Cost per GB
Batteries for laptop not practical
Loads of SxS cards
Not affordable
MxS/KxS/PCI-e adapters with SDHC
Pros -
Relatively low cost
Small footprint
Cost per gb = low
Cons -
Reduced feature set for overcrank
Not thoroughly proven yet
And the NEXTO 2725 + Adapter solution
Pros -
Full feature set
Re-use existing SxS
Cost per GB - lowest e.g. for 1k budget
Low battery weight/cost
16gb transfer time approx 20 mins (EX)/11 mins (P2)
Field replaceable HDD and transfer i.e. HDD2HDD backup possible
Field capacity limited to number of 2.5" HDD we can carry
Cons -
We have to get the ridiculously expensive SBACUS10
Footprint not as small as the PCI-34/SDHC solutions
HDD not as robust as SDHC
Let me have your thoughts on this or if anyone has tried this solution.. please share your experiences...
PS.. i have considered the MXF + Nexto but for myself, I feel the need to have full overcrank possibilities at all times.
Links:
http://www.nextodi.com/en/
Sony SBACUS10
Pros -
Full feature set
Field Review/Edit
Cons-
High Cost per GB
Loads of SxS cards
Not affordable
Pros -
Relatively low cost
Small footprint
Cost per gb = low
Cons -
Pros -
Full feature set
Re-use existing SxS
Cons -
Links:
