Braindead@70
I am looking for a wallet to hold 8-10 SXS cards. HELP!
The Case Logics do come in different colors, but using two cases is too complicated and easy to mess up. All my cards are labeled and numbered so on most shoots I just use them in numerical order.
But the technique I use for documentaries, run & gun, and multi-cam shoots (where chaos is likely to be happening), I have small yellow rubber bands that go around empty cards. If a card has a rubber band, it is empty, formatted, and ready to roll. If a card does not have a rubber band --- DON'T PUT IT IN A CAMERA. That system has worked perfectly for years and years. The rubber bands are cheap (throw them away after each use) and it is impossible to use the card without taking the band off.
