macgregor
HI all.
I'm getting ready to go back to Mauritania (Africa for those of you with low geography skills) this month to finish shooting the documentary I started last year. But like previous time, I don't want to ruin my "expensive" sony Cinealta PL mount lenses.
Last time I took my sony F35 with a Nikon mount so I could use Nikon and Samyang lenses. But my camera is back to PL mount so Nikon lenses are out of the question.
Therefore I'm looking for affordable PL mount lenses that I can take with me and not cry in the event of them getting damaged (last year all the lenses survived fine though).
So I've spent days researching for the best possible lenses for this production. I don't want to carry a ton of lenses, so I'm limiting myself to just 3-4 lenses: a wide angle (16mm), a medium (40mm ideally), and a telephoto (135mm). The ex-soviet union countries seem to be selling their lens arsenal for really cheap prices. Most lenses are pretty beat up, but sometimes you can find cool stuff. This is my research in case I help some fellow dvxuser:
- Rollei HFT Planar 50mm f/1.8 http://www.ebay.com/itm/Arriflex-Ar...d=100011&prg=9834&rk=2&rkt=10&sd=111372490105
I wasn't able to find a better deal for a mid range lens than this. I did a bit or research on this lens and all I could find was that it was just a fine lens. After all, 50s seem to be the easiest to build. This is a rehoused still lens from Singapur/China. So I risked it and I ordered one. I've seen them on ebay for around $450. Hell yes, lets do it.
The lens arrived today. As expected is tiny, a bit smaller than a Zeiss Standard. It seems pretty solid. THe iris ring is not declicked. And being so small it's really hard to reach the iris ring. But I did a really quick comparison test against the Cinealta 50mm and I can't tell the difference between both. So performance seems surprisingly decent. Great for ultra low weight set ups?
EDIT. optics quality is good, construction is bad, they end up braking. Avoid.
- Helios 58mm 44-2 f2 with PL mount adapter
You all probably know about this lens. Old, crappy, and cheap. But it produces beautiful bokeh and amazing lens flares. So it's a must have (I have 3 units). Better to choose a mint unit otherwise they're all pretty much destroyed by now. This lens is great for artistic stuff but it doesn't have enough contrast and resolution for my project.
But what's great about the copy I recently purchased is that it came with a M42 to PL mount screw in adapter. Which means I could potentially attach the adapter to any M42 lens (they're cheap and easy to find) and voila! A new world of lenses for us.
Unfortunately it's not that simple because of size constrains. The taking lens must have a small rear size to fit inside the adapter. However I was able to find another M42 lens that can be "converted" to PL mount with the same adapter:
- Carl Zeiss Jena Sonnar 4/135mm.
I didn't know much about this lens until last week when I found out that it could be attached to the F35 with that same M42-PL mount adapter. I did some research and despite being suuuuper old, I read that it produces magnificent pictures. So I got one. It's tiny! I quickly tested it. Fantastic focus 340deg focus rotation. Declicked iris ring. And it's sharp and shows good contrast!!!
I'll check it out tomorrow with sunlight but I'm pretty excited about it. Also, compared against my Cinealta 135mm T2.0, the Jena seems to have a longer focal length than 135mm (more like a 150mm) or the sony is shorter than the claimed 135mm.
- TAIR-33 4.5/300mm
Again, another lens I hadn't heard in my life. But after doing some research, it seems to be also a decent performer. And for $200 and in PL mount, definitely worth checking it out. For documentary stuff, it's going to be handy to have a nice 300mm lens. I'll let you know how this thing works once I receive the unit.
As you can see I'm still missing a wide angle lens. And this is going to be hard since there aren't that many wide/good/cheap options. I think the cheapest option would be a tokina 11-16 with a PL mount. I've seen them on ebay for $1500-2000. But this lens has too much CA for my taste.
Any ideas?
- TAIR-33 4.5/300mm
Any ideas?
