disco_al
I help to run a school tv channel, and we are about to buy two new cameras for studio use.
I used to be a studio cameraman myself, and what i want to have for these new studio cams, is the ability to view the live program (Tx) feed while operating each individual camera (i.e. the "return" feed, usually selected by pressing the return button on the camera handle, which toggles between the return feed and the camera's own feed on the viewfinder/monitor).
Because we can't afford high-end studio cameras, we are considering the Panasonic AG-HVX200 (but if you have any reccomendations in this price range, that might serve us better then please let me know!), and so with this camera or others like it, i think there are three ways to achieve what i need:
1. 1 LCD monitor with 2 video inputs that can be switched, mounted above each studio camera. Only problem with this is having to reach up to and press a switch on the monitor itself, which is a little awkward and may shake the camera. If there's a way to switch the sources going into the monitor with a remote or extended control that could be fixed to the camera arm, that would work. Anyone know of anything like this?
2. 1 LCD monitor with 1 input, along with an additional video switcher, taking in two feeds and feeding one to the lcd monitor on the camera, with the switch mounted to the camera arm. Does a "simple" switch like this exist, where by it allows one feed through unless the button is pressed causing the other feed to be displayed?
3. 2 LCD monitors that can be mounted together (stacked or side-by-side)above the studio camera. Does anyone know of a monitor or mount that can accomodate this? Doing it this way requires buying 4 instead of two monitors, but would eliminate the need to switch feeds. Any ideas?
So that's my dilemma. If anyone can offer any help with either solution, or offer any alternate solutions to my problem, i will greatly appreciate it.
Surely I am not the only person out there using "DV-style" cameras in the studio, who wants to have pro-style return video control/viewability?
