Strobe or Interference on my DSLR T3i
Jamaine
All,
Am getting some sort of interference or strobing effect on my DSLR when recording. They are like some lines rolling from the bottom to the top of the screen.
I Followed the 180 rule, and I was using a 1000wt fluorescent light and still getting the strobe effect. is there anything else i need to double check.
yes: the 180 rule is approximate, much more important than that is that you have to set a shutter speed that does not create flickering with your lights
check the link I posted up there
Whiat is your countries region? remember PAL and NTSC run differen Hz. 50/60hz respectively.
Adjust footage region to pal/ntsc, adjust shutter speed and FPS to match your regions Hz.
Ie: 50hz PAL region, set DSLR to PAL, and match shutter speed until you are rid of Hz 'flicker'
