Ok, I just got 2 new SATA 300GB (16Meg cache) hard drives. I'd like to know the exact procedure to "stripe" (initialize/format) them strictly for Avid usage. In the BIOS, I set the drives for 32Bit transfer enabled.
We use the standard drive utlitlites that are part of the OS. Just go to the drive utilties, select both drives and stripe them as a pair. NTFS is the formatting "format". You can use "Quick Format" so you don't wait hours.
Yes it is. Now that the drives are formatted, you want to stripe them. I'm not in front of a system with multiple drives to take you through the steps, but you can search the WIndows XP Help for how to do this.
I figured it out. I can, indeed, "stripe" the drives. I was reading up on what "striping" actually is . . . it seems that it makes the drives work together, almost like a RAID?
My concern is that these are removable drives that I will eventually be swapping out with (future) additional drives that I will expand to as my editing projects demand. So, should I still "stripe" them or leave them as 2 seperate and dynamic NTFS-formatted volumes?
It's harder to move striped drives around as the striping information needs to travel with them. Teh purpose of a stripe is to increase the bandwidth of the drive allowing for hiogher resolutions or real time streams. If you plan on using these as editing and shutle drives, I would not strip them.
