Ok, you know the noise that the recorder components makes whenever you insert a tape or when the camera goes into standby mode? Well.. I've noticed this with my camera... Often(but not always) after a REC segment, the gears(or whatever that's inside) would make noise for like 5 or 6 seconds during of which, the green "PAUSE" indicator dissapears and a red tape icon would flash at the top corner of the screen for a split second. The TC would also reset temoporarily back to 00:00:00:00. Usually 5 or 6 secs later, the noise stops, the PAUSE indicator comes back and my TC is restored to what it should be. Does anyone else experience this? THanks
